    Apr 2013
    Norway
    30
    2
    Trane RTWB oil changing procedure
    Hi. Not sure this is the right place to ask this but i am about to service a couple of RTWB 208, 212, 218 chillers, but cant find any procedure to do so. The compressors does not have sightglass on the side to watch the oillevels. So i wander if you guys have a manual/procedure to change the oil in the compressor on theese?
    Martin
    Sep 2010
    70
    209
    10
    Re: Trane RTWB oil changing procedure
    Trane do not recommend routine oil changes although oil analysis should be done.
    Check oil level in separator however.
    Manual..... https://www.google.co.uk/url?sa=t&so...Y3Dc00jCA6bAOQ
    Apr 2013
    Norway
    30
    2
    I saw that manual too. But lets say the acid test indicated acid in the oil and the oil must be changed. How do one do that? Tbh ive allready drained one compressor and separator.
