Results 1 to 2 of 2
    Mar 2017
    Jordan
    1
    Power consumption in a walk-in freezer room
    Hello,
    I have been looking for an equation that helps me calculate the power consumption in a walk-in freezer at different temperature levels, but with no luck so far.
    The freezer volume is 13x11x8 meters cubed. Temperature is set to -24 degrees Celsius and I need to find difference in power consumption if temperature was lowered to -18 degrees Celsius.
    Also, how can I calculate the infiltration losses of a walk-in freezer room?
    Mentioning a reference would be much appreciated.
    Thanks in advance!
    May 2012
    1,279
    29
    Re: Power consumption in a walk-in freezer room
    Power consumption can be calculated using a pH chart
    See
    http://www.en.ipu.dk/Indhold/refrige.../coolpack.aspx
    Rob
