Thread: Oil change
    Mar 2016
    IRAN
    154
    3
    Oil change
    Dear Friends,
    When we buy fridge we do not change compressor oil for many years, But some one tell that we must change oil of compressor at for example R22 system after for example 500 operation hours.
    Which one is true ?
    Sincerely yours.
    70
    10,548
    52
    Re: Oil change
    Always check with the manufacturer what time/usage period they recommend.
    Mar 2016
    IRAN
    154
    3
    Re: Oil change
    Thanks Brian_UK
    Jan 2006
    Croatia
    2,134
    Re: Oil change
    Hi, A.Mortezania
    Quote Originally Posted by A.Mortezania View Post
    Dear Friends,
    Which one is true ?
    Sincerely yours.
    Regarding lube oil change within some recommended time ... home fridges are out of this story ... it is a small closed system manufactured under special conditions ... very clear environment and clear assembling parts ... reason to last a (too)long time ... need to replace them because their outlook is old-fashioned ...
    Other custom made systems required (at least it is recommended by manufacturer) lube oil change by working hours, but the best is to examine lube oil in laboratory and then change if needed.
    Industrial systems are the same ...usually we have a big amount of very expensive lube oil and definitely not cheap to replace it.
    So the best is to check lube oil first.
    In your case I believe it is not a big amount of lube oil and suggestion is not bad. To protect your system it is better to replace lube oil together with filter drier/s.
    Best regards, Josip
    Mar 2016
    IRAN
    154
    3
    Re: Oil change
    Quote Originally Posted by Josip View Post
    Hi, A.Mortezania
    Best regards, Josip
    Thanks a lot Josip
