    Mar 2016
    IRAN
    157
    3
    Compression ratio
    Dear Friends,
    I have a question. Do you have any document that explains refrigeration compressor compression ratio at air-conditioning system and refrigeration systems ?
    Thanks.
    Feb 2008
    57
    Re: Compression ratio
    Compression ratio = Discharge pressure / Suction pressure. (Absolute pressures should be used).
    The smaller the ratio is, the more efficient the pumping is.
    If the ratio is high, less refrigerant mass is pumped over a given time especially in piston compressors, therefore more energy is consumed over time by the compressor motor or drive to achieve the same refrigerating effect as opposed to a low compression ratio.
    Lower compression ratio = more pumping.
    Higher compression ratio = less pumping.
    No documents but hope this helps.
    Jan 2006
    Croatia
    2,136
    Hi, A.Mortezania
    it is archived a lot of answered questions here on RE forums ...
    but you need to do searching by yourself ...
    sometimes much better if you want to learn something .... believe me
    RE archive is like ... Treasure chest ...
    Quote Originally Posted by A.Mortezania View Post
    Dear Friends,
    Thanks.
    check here,please..
    http://www.refrigeration-engineer.co...ression-Ratios
    also www is full of documents like this one ...
    http://www.hvacrinfo.com/cope_ae_bulletins/TAE1268.PDF
    http://nptel.ac.in/courses/Webcourse...cture%2019.pdf
    Best regards, Josip
    Mar 2016
    IRAN
    157
    3
    Dear Josip and Inverter man,
    Thanks for help of both of you.
    Sincerely yours.
