Thread: Beko d70410
    Dec 2010
    Greece
    179
    8
    Beko d70410
    HELLO!
    Does any of you have the manual for a BEKO ,product code DSE41020,MODEL D70410, refrigerator?
    I want to find the resistance value of thermistors.
    The problem is that the refrigerator does not cut off regularly.
    Dec 2010
    Greece
    179
    8
    Re: Veko d70410
    Sorry the refrigerator is BEKO.
    Sep 2003
    ISRAEL
    66
    4,152
    38
    Re: Veko d70410
    You think that the resistance value of thermistors will be on their manuals?
    Try to contact the manufacturer.
    Dec 2010
    Greece
    179
    8
    Re: Beko d70410
    where can I find them????????
    it is better by trial and error to change thermistors.
    I also noticed the the interior fan fan is not working all the time.it is controlled by a pcb
    Sep 2003
    ISRAEL
    66
    4,152
    38
    Re: Beko d70410
    You can get the value from a new parts.
    the fan is controlled by the evaporator temperature measured by a thermostat so it sounds ok.
    Check the refrigerant charge.
    Dec 2010
    Greece
    179
    8
    Re: Beko d70410
    I am in a big trouble.I changed the air sensor with a new one but the fridge does not stop.
    I measured -5 C at the fresh food compartment.
    Does any of you have any information about the control circuit or the sensors.I also noticed that the indoor fan does not operate. That is why I suspect the control circuit.
    control circuit:
    PENTA elektronik
    ( K2 – V16 KV ĒK – Kardelen / 4360621685 )
    air sensor :Nova elektronik
    Tip-Model : 4216601585
    evaporator sensor: Nova elektronik
    Tip-Model : 4216601185
