Results 1 to 13 of 13
Thread: Brazing
    Aug 2004
    45
    746
    Brazing
    Good afternoon chaps.
    I have just found out that a job we are starting doesn't allow acetylene on site. How do I braze the big pipe on my VRV?
    What would you use if you had to change a compressor?
    Sorry for the schoolboy questions but I've always used oxy/acet on pipes 3/4 and up and only ever used it on comp changes & VRV/VRF connections.
    Eggs
    Aug 2014
    South Africa
    35
    26
    Re: Brazing
    You could always try the zoomlock from sporlan, but theres added chances of leaks.
    70
    10,650
    52
    Re: Brazing
    Use propane/oxy.
    Sep 2003
    ISRAEL
    66
    4,171
    40
    Re: Brazing
    You will need different tip for propane, brazing temp is a bit lower but there will be no problems.
    I only use it for every braze I do up to 3" pipes.
    44
    3,803
    Re: Brazing
    Oxy Propylene is what i use, https://www.youtube.com/watch?v=G7Dkfa0Si70
    Feb 2009
    telford
    2,094
    27
    Re: Brazing
    Me too,as said the tip needs to be larger and acetylene is one heavy bottle.
    Dec 2010
    devon
    47
    793
    Re: Brazing
    We had this recently on one site we used Vulcan lock rings that site we could not use acet or profuel nothing so we braised the big joints outside the property then used Vulcan on smaller stuff and got um to sign a waiver if Vulcans ever leak
    Aug 2004
    45
    746
    Re: Brazing
    Thanks chaps. I'll look in to propane then.
    Why on earth you can use one gas and not the other is beyond me. Am I less lightly to torch the shopping centre with mapp gas or propane than acet ?
    The mind boggles
    Eggs
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    439
    26
    Re: Brazing
    Probably the sensible thing would be to approach the project management team with your facts and figures to see why the blanket ban is in place as usually you can get it lifted with the correct procedures in place.
    Show that you insurance covers you to work with oxy / acet (I usually find our subcontractors do not have sufficient cover even for Mapp gas let alone Oxy / Acet)
    Have you RAMS prepared in advance with decent control measures, including outside cage storage for gases with extended length pipes for work etc.
    Thermal camera post work surveying for hot spots each day post works etc.
    Blanket banning on construction sites is just a usual approach to prevent the cow boys shootin and tootin!
    Aug 2004
    45
    746
    Re: Brazing
    That makes sense Marc. I'm on a mission to get the blanket ban overturned because I'm a special little snowflake. Not like the rest..
    I'll keep you posted on how I get on.
    Eggs
    Aug 2004
    45
    746
    Re: Brazing
    Apparently we need a:
    Turbotorch STK-11 Double Barrel Brazing Torch with some mapp gas.
    They're the future, just like garlic bread..ill give it a whirl. Anybody tried one?
    44
    3,803
    Re: Brazing
    They are ok, but use a lot of mapp, have done 1 3/8" with it inside with no wind etc.
    Sep 2003
    ISRAEL
    66
    4,171
    40
    Re: Brazing
    Quote Originally Posted by eggs View Post
    looks like a toy, you need oxygen for brazing copper or it will take you a long time.
    propane and oxygen torch is what you need.
