Thread: S-Net for Samsung DVM
10-05-2016, 11:41 AM #1
Hi guys.
You know where I can buy the S -Net converter for Samsung DVM ?
The reference , I think, DB81-02331A
Thanks in advice.
10-05-2016, 08:44 PM #2
Re: S-Net for Samsung DVM
Hi Miguel and welcome to the forum,
The code you got there is for the older interface (what in Samsung language is referred to as pre-NASA), it will let you connect to older DVM systems, current splits and older domestic heat pumps.
What you really want is a DB97-22229A, this is the current interface that "speaks" the new language (referred to by Samsung as NASA), this not only let you connect to the current and future models but is also backwards compatible so will communicate with everything Samsung AC.
You will also need the software to go with it (Free), for older stuff and splits it is called SnetPro and for the newer NASA stuff it is SnetPro2.
Unfortunately I do not know who stock it in your neck of the woods, sorry.
EDIT: The above part numbers is if the interface is ordered as a spare part, they are also available as accessories and then they are called: MIM-C02 and MIM-C02N respectively, you do want the one with an N at the end. (Just in case it is easier for you to find someone selling units than someone selling spares)Last edited by The Viking; 10-05-2016 at 08:47 PM.
11-05-2016, 04:47 PM #3
thanks for the tip.
the program already have, just missing the converter.
I have the original converter for Mitsubishi Electric , but appear a Samsung from time to time and convert it makes fault .
i got to keep searching....
15-05-2016, 11:02 AM #4
For all DVM system you can use usb-485.
DVM-S need samsung converter.
17-07-2016, 02:08 AM #5
hello, i have a question, can i use the usb-485 (not original samsung) for the samsung dvm plus III ??
thanks.
19-07-2016, 03:18 AM #6
thanks.
19-07-2016, 07:13 AM #7
yes, you can
26-10-2016, 02:39 PM #8
You can buy it from this company,www.cyclogic.net
They are the manufacturer of this converter.
