Results 1 to 8 of 8
    Mar 2016
    Angola
    2
    S-Net for Samsung DVM
    Hi guys.
    You know where I can buy the S -Net converter for Samsung DVM ?
    The reference , I think, DB81-02331A
    Thanks in advice.
    Feb 2007
    2,479
    38
    Re: S-Net for Samsung DVM
    Hi Miguel and welcome to the forum,
    The code you got there is for the older interface (what in Samsung language is referred to as pre-NASA), it will let you connect to older DVM systems, current splits and older domestic heat pumps.
    What you really want is a DB97-22229A, this is the current interface that "speaks" the new language (referred to by Samsung as NASA), this not only let you connect to the current and future models but is also backwards compatible so will communicate with everything Samsung AC.
    You will also need the software to go with it (Free), for older stuff and splits it is called SnetPro and for the newer NASA stuff it is SnetPro2.
    Unfortunately I do not know who stock it in your neck of the woods, sorry.
    EDIT: The above part numbers is if the interface is ordered as a spare part, they are also available as accessories and then they are called: MIM-C02 and MIM-C02N respectively, you do want the one with an N at the end. (Just in case it is easier for you to find someone selling units than someone selling spares)
    Mar 2016
    Angola
    2
    thanks for the tip.
    the program already have, just missing the converter.
    I have the original converter for Mitsubishi Electric , but appear a Samsung from time to time and convert it makes fault .
    i got to keep searching....
    Oct 2012
    Russia
    36
    390
    12
    For all DVM system you can use usb-485.
    DVM-S need samsung converter.
    Jul 2016
    Chile
    2
    hello, i have a question, can i use the usb-485 (not original samsung) for the samsung dvm plus III ??
    thanks.
    Jul 2016
    Chile
    2
    thanks.
    Oct 2012
    Russia
    36
    390
    12
    yes, you can
    May 2010
    Seoul
    2
    You can buy it from this company,www.cyclogic.net
    They are the manufacturer of this converter.
