Results 1 to 10 of 10
    Mar 2011
    Tangerang
    31
    8
    Brazing technique
    Which one is better, brazing use dual torch or single torch ?
    Somerset
    64
    4,590
    Re: Brazing technique
    Hi Aria.
    Some of the main questions to ask are -
    Is the mass of the joint to be Brazed large enough to require the extra heat generated by a twin torch?
    Can the extra heat be controlled so as to not damage items nearby?
    Using the extra torch can ensure an even heat application, which will give greater uniform penetration.
    Conversely, Is a more local heat required?
    Which a single torch can provide, it is rare in fridge work where 2 torches are necessary.
    Also the gas consumption makes it an issue for site work, if you are workshop based then it is an easier option to adopt.
    Dual torches are fairly aggressive in their heat application so are less versatile.
    At the end of the day, its all about how much heat you want or need to apply and of course.
    What is the minimum needed to achieve a good result.
    I for one rarely use a dual torch but have been known from time to time I have enlisted assistance from a second person holing a second torch.
    44
    3,802
    I would say for production work in a factory a dual torch is better but for working out in the field, repairing or installing stuff a single is a better choice.
    Split Croatia
    6,108
    30
    On small pipes with little maneuvering place around, I usually use Gloor two headed torch! Excellent for not burning anything around! Flames are directed at 180 to each other and almost nothing around is damaged by flame. Also, time for preheating and brazing is halved!
    It takes some practice for the brain to adapt, but after that, it is much easier than with single head. It is my first choice for all joints including and below 18 mm diameter pipe!
    Feb 2007
    2,477
    Simple...
    The one that is held by an experienced engineer!
    Somerset
    64
    4,590
    Quote Originally Posted by The Viking View Post
    Simple...
    Ouch!
    But true all the same!
    Sep 2003
    ISRAEL
    66
    4,160
    One of the things to remember, Always the herder metal on the outside of the brazed joint.
    Mar 2011
    Tangerang
    31
    8
    Thank you for your reply.
    now i'm already move to another company. My old company use single torch, with smaller leakage (by ppm) than my new company that use dual torch. Is there any critical check point, especially for brazing steel to copper? i.e technique lubricating flux, or material flux selection and etc
    Mar 2011
    Tangerang
    31
    8
    about fluxing method, which one is better, flux lubricating on pipe or flux mixing on filler (heat by flame) ?
    Sep 2003
    ISRAEL
    66
    4,160
    Its only a matter of comfort and cost.
