Results 1 to 12 of 12
Thread: Carlyle 06N
11-08-2015, 07:56 PM #1
Carlyle 06N
Hi.
Can't find a manual for rebuilding of that compressor. Оnly find instructions for the replacement of the multiplier.
Anyone can help?
11-08-2015, 10:30 PM #2
Re: Carlyle 06N
Hi my friend.
An email to both of your email addresses that I have has been sent.
Follow the link to the file which you can then download, only it was too big to upload or email.
11-08-2015, 11:03 PM #3
Re: Carlyle 06N
12-08-2015, 10:23 PM #4
Re: Carlyle 06N
Hi they are really easy to rebuild,once you get the gear wheels off,tools you need are a big gear puller,E14 torque socket,18mm socket,19mm socket,set off feeler guages,and a bottle off map gas to heat the bearing rings on and off and a 19mm spanner.leave discharge clearance of 2thou,
15-08-2015, 07:54 PM #5
Re: Carlyle 06N
I never rebuild them. Sow it will be intersting.
Todays work. Will be repair it.
15-08-2015, 11:49 PM #6
Re: Carlyle 06N
Hi that picture is not an carrier 06n screw compressor
16-08-2015, 12:57 AM #7
Re: Carlyle 06N
Before rebuilding, what went wrong to cause it?
Wrong direction for whatever reason or something else!
Is it worth getting a new one for such a small machine.
16-08-2015, 05:05 AM #8
16-08-2015, 08:46 AM #9
Re: Carlyle 06N
Its Bitzer compressor. My fault.
Repair the compressor at night, and forgot to tighten the bolts on nuts of rotors. 20 seconds and this result). I milled the discharge flange and ends of the rotors. Add spacers under the bearings and the motor rotor.
16-08-2015, 11:29 AM #10
Re: Carlyle 06N
I have a problem with searching a table on maximum / minimum wear limit for Bitzer semi hermetic compressor S4G-12.2 I tried searching every Bitzer technical information and still could not find anything on limit wears.
It is so worrying too that sales agents does not provide such vital information as it would greatly help in sizing up compressor rotating components that are badly scored and needing machining.
Anyone has a clue where to get this table on limits.
07-10-2015, 09:56 AM #11
Re: Carlyle 06N
I am looking for a Manual for removing the gear disc. have tried with heating the disc and pulling it with a gearpuller.
07-10-2015, 09:57 AM #12
Re: Carlyle 06N
can you send the link to med too? adrian.edberg@huurre.se
