Results 1 to 12 of 12
Thread: Carlyle 06N
    Oct 2012
    Russia
    36
    391
    12
    Carlyle 06N
    Hi.
    Can't find a manual for rebuilding of that compressor. Оnly find instructions for the replacement of the multiplier.
    Anyone can help?
    Somerset
    64
    4,581
    Re: Carlyle 06N
    Hi my friend.
    An email to both of your email addresses that I have has been sent.
    Follow the link to the file which you can then download, only it was too big to upload or email.
    Oct 2012
    Russia
    36
    391
    12
    Re: Carlyle 06N
    462
    15
    Re: Carlyle 06N
    Hi they are really easy to rebuild,once you get the gear wheels off,tools you need are a big gear puller,E14 torque socket,18mm socket,19mm socket,set off feeler guages,and a bottle off map gas to heat the bearing rings on and off and a 19mm spanner.leave discharge clearance of 2thou,
    Oct 2012
    Russia
    36
    391
    12
    Re: Carlyle 06N
    I never rebuild them. Sow it will be intersting.
    Todays work. Will be repair it.
    462
    15
    Re: Carlyle 06N
    Hi that picture is not an carrier 06n screw compressor
    2,564
    28
    Re: Carlyle 06N
    Before rebuilding, what went wrong to cause it?
    Wrong direction for whatever reason or something else!
    Is it worth getting a new one for such a small machine.
    moideen's Avatar
    moideen is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2008
    u.a.e
    43
    417
    Re: Carlyle 06N
    Hi my friend.
    hi friend,
    please send to me,i need that manual.
    thanks
    moideen
    Oct 2012
    Russia
    36
    391
    12
    Re: Carlyle 06N
    Its Bitzer compressor. My fault.
    Repair the compressor at night, and forgot to tighten the bolts on nuts of rotors. 20 seconds and this result). I milled the discharge flange and ends of the rotors. Add spacers under the bearings and the motor rotor.
    Jul 2010
    fiji islands
    14
    Re: Carlyle 06N
    I have a problem with searching a table on maximum / minimum wear limit for Bitzer semi hermetic compressor S4G-12.2 I tried searching every Bitzer technical information and still could not find anything on limit wears.
    It is so worrying too that sales agents does not provide such vital information as it would greatly help in sizing up compressor rotating components that are badly scored and needing machining.
    Anyone has a clue where to get this table on limits.
    Apr 2014
    Sweden
    2
    Re: Carlyle 06N
    I am looking for a Manual for removing the gear disc. have tried with heating the disc and pulling it with a gearpuller.
    Apr 2014
    Sweden
    2
    Re: Carlyle 06N
    can you send the link to med too? adrian.edberg@huurre.se
