Results 1 to 16 of 16
02-10-2014, 09:45 AM #1
Re: Variable Amperage And Cold Liquid line
Discharge 225 psi
Suction 45 psi
Amperage between 35 - 50 ( copeland scroll / nominal 30 A)
Unloaded: 13 A
And the liquid line is cold specially after sight glassLast edited by hsn157134; 02-10-2014 at 09:50 AM.
02-10-2014, 06:16 PM #2
Was your indoor unit running as heat pump or cooling?
Have you checked compressor winding?
After sight glass should be warm subcooled liquid. If its cold that could be a sign short of refrigerant. If you refer to PH chart you will know the compressor will always pull too many amps when its under charged.
