20-09-2014, 10:53 AM #1
Vaporex 33 dehumidifier manual / advice?
Can anyone help me out with a manual for a vaporex 33 dehumidifier? I saw a couple of folk in older threads had them but the links are dead.
Problem is that the fan won't start - I've checked the capacitor and it appears to be fine (2uf cap, says 1.96 on multimeter). The fan is a chinese make and I can't find any spec sheets on it, but I'm starting to think that's the problem.
I hooked up the fan direct without the cap, and it will run if you give it a good shove to start.
Any ideas would be very welcome!
Cheers,
Tom.
20-09-2014, 10:59 PM #2
Re: Vaporex 33 dehumidifier manual / advice?
Well it's not the fan or the capacitor, got that running fine on the bench. I've waded my way through most of the components...switches, timers, humidistats all fine. Tomorrow I need to check the relay that is controlled by the temperature probe. No idea how to test that though - looks solid state.
21-09-2014, 12:20 PM #3
22-09-2014, 11:56 AM #4
