Results 1 to 2 of 2
Thread: simple stuff
    Oct 2010
    dublin
    31
    7
    simple stuff
    Hi guys
    Sorry for d basic q's
    What should my pressures be on a small display chiller? Setpoint 2c gas 404.
    Also another similar cabinet chill slight ice build up at start of evap coil could this be low in gas or just because d fridge is empty ?
    Feb 2007
    2,477
    Re: simple stuff
    the pressure should be 123456578...
    Yepp, it could be low on charge... Could also be a myriad of other things.
    To start with you need to check the running conditions of your system, discharge & suction pressures, Subcooling and Superheat, air on /air off evaporator & condenser and so on.
    Then, and only then, can we make judgement on how the system is operating and why.
