    Nov 2013
    42
    33
    Hitachi RAK 50PPA ... Additional tank pump
    If anyone can help , we have fitted a hitachi single split wall mount and need to fit pump on it to . my question is as the interconnecting cable is only a 2 core for terminals c&d
    is it possible to wire the pump into the indoor unit to power the pump ? Thru these terminals ??
    I know that a mitsubishi wall mount for instance the 1,2,3 terminals that 1 is always the live & 2 neutral
    Mar 2006
    Lancashire
    1,859
    28
    Re: Hitachi RAK 50PPA ... Additional tank pump
    Quote Originally Posted by Cmsaircon View Post
    You probably know this already but the pump should be connected into a dedicated fuse spare
    Marc
    Oct 2007
    manchester
    5,639
    45
    try it off the original supply to the indoor- or pinch some juice off the closest light fitting
    Oct 2013
    36
    147
    14
    twist and tape. Just remember to turn AC off at same time as lights.
    Nov 2013
    42
    33
    Sorted it guys , the job was installed without me knowing that the unit fitted couldn't have an external pump wired direct to the indoor . Got a separate spur pulled in , job done !! ( the lights are safe ) !!! :0)
