    Feb 2014
    Davis, CA
    34
    2
    Question Pedal powered compressor
    Hi all,
    I'm not an expert on this topic but I have an idea for a hobby project that I hoped I could get some feedback on here.
    I'm interested in trying to make a pedal-powered ice-cream-and-frozen-drink maker that runs a compressor directly. I'd like to know the feasibility of this. Some back-of the envelope calculations:
    - A typical biker can put out about 200 watts (~1/4 hp) continuously
    - I'd be aiming to cool about 1 quart of liquid from room temperature to frozen. Given the specific heat and heat of fusion of water, this amounts to change of energy of 120 Watt-hours.
    - If the coefficient of performance of the system is 2, then one should be able to cool the liquid in about 20 minutes (120 W-h/ (2* 200 W)).
    So this seems theoretically possible, but one would need a compressor and refrigerant system that fits the bill. It would have to be a compressor that could be efficient when run by an external belt/crank giving about 1/4 HP. One can use gearing to increase RPM, but it would be best if the RPM required were < 2000 RPM. And the refrigerant should evaporate at a below-freezing temperature.
    Main questions:
    - I'm sure I'm missing some major considerations - what are they?
    - What compressor would fit this bill? I thought that maybe something designed for A/C of compact car might do. As far as I can tell, all compressors designed for small fridges (or countertop ice cream machines) are hermetically sealed combined motor/compressor units.
    - What refrigerant would make sense? If this could be done with propane, it would make the DIY aspect easier.
    Thanks for your help!
    Jul 2010
    NTH.QLD Australia
    55
    1,755
    26
    Re: Pedal powered compressor
    "Legging it" has taken on a new meaning in this post.
    If i had to provide stable cooling in your situation, i would use a 300 Amp/Hour battery to power a Danfoss 12/24 DC compressor and top up the battery by leg power.... driving an old 35 amp vehicle alternator.
    That way you can take a break to catch your breath.
    69
    10,509
    Don't forget that you also need to power a condenser as well.
    Feb 2014
    Davis, CA
    34
    2
    Could the condenser be passive? That is, just a set of coils that the refrigerant passes through with a lot of surface area? I suppose a small mechanical fan blowing air over the coils would boost the efficiency a lot without a lot of additional effort for the biker.
