    Jan 2014
    Pakistan
    27
    1
    Need Help In vapor absorption Refrigeration
    hello. can anybody help me to design vapor absorption refrigeration system which should have the cooling effect of 80KW. refrigeration capacity should be around 25-30 tonn. purpose of refrigeration is to liquefy the co2 gass.
    Aug 2013
    china
    37
    2
    Re: Need Help In vapor absorption Refrigeration
    it is kind of difficult, because you did not give the chilled water temperature and cooling water temperature
    Mar 2009
    U.S.A.
    300
    13
    This a brewery or?
    http://www.tespl.com/ammonia-absorpt...on-plants.html
    Have a depth of experience with a variety of industrial processes using Aqua Ammmonia absorption.
    You can absorb CO2 directly in a refrigerant cycle but the cost of heat exchange and similar is pretty high due to the pressures involved.....Its feasible at small scale with both liquid and solid absorbents but at industrial scale it gets a lot of expensive.
Tags for this Thread
