Results 1 to 16 of 16
    Oct 2001
    Nottingham UK
    5,668
    Show us your installs....
    Thought I would kick this off with a couple of photo's of a recent Ground Source Heat Pump rebuild. Original system failed due to a split BPHE causing the ground loop to mix with the fridge side. Had to provide a replacement compressor, BPHE's, safeties and pipework. Kept the same controller.
    Oct 2001
    Nottingham UK
    5,668
    Re: Show us your installs....
    Here's a picture of the original layout
    Oct 2007
    manchester
    5,639
    45
    nice job, but u insulated the liq line!
    feel free to remove this comment if you like
    Oct 2001
    Nottingham UK
    5,668
    Quote Originally Posted by install monkey View Post
    Bu**er....could have saved some money
    Jul 2009
    South Africa
    79
    195
    Wow, that looks a lot neater than my fridge units. Can I ask how did you get the tube type foam insulation on the pipework after it was welded?
    ireland
    54
    275
    26
    Why add the oil seperator, accumalator and bypass valve? or are there parts hidden from view on the original
    Oct 2001
    Nottingham UK
    5,668
    On the original setup, we found that one of the PHE's was filled with oil when we disassembled it, thinking that it was short cycling, thus not allowing time for the oil to be returned to the comp, so we built in the oil separator to prevent oil carryover.
    As the unit is reversible, we were concerned that, on change over (it doesn't off cycle to do it) the compressor could be susceptible to liquid flood back without the accumulator. Also, as it changes mode, the time required by the hot gas to push the liquid out of the PHE caused the LP switch to trip, thereby stopping the unit.
    I have built in the HGB valve on a double pole delay timer which bypasses the LP and HGB's for 40 secs, which now allows change over without tripping/stopping.
    Oct 2001
    Nottingham UK
    5,668
    Quote Originally Posted by Frikkie View Post
    You cut the insulation tube with scissors or stanley knife and then use glue on the seams.
    Jul 2009
    South Africa
    79
    195
    Thanks for the info, I've also tried cutting and gluing the insulation but it never looks as neat as yours
    ireland
    54
    275
    26
    Ok makes sense, perhaps a case of how it was made and how it should have been made.Manufacturers tend to lose a lot of parts to make their costs cheaper
    Oct 2001
    Nottingham UK
    5,668
    Quote Originally Posted by joe-ice View Post
    Spot on Joe.
    Don't want the customer chasing me if the unit failed a second time because of poor design.
    Somerset
    69
    4,698
    HI.
    If you are lucky you have a slitting knife, which makes the job even easier.
    Ones like the attached are quite cheap here in the UK at least (around £10.00)
    Oct 2007
    manchester
    5,639
    45
    3,856
    Nice work Frank!
    Was aiming for an old school look with this one...
    https://www.youtube.com/watch?v=pSBr5qB5OPk
    Ice builder system,
    https://www.youtube.com/watch?v=cFX9aRR2Dlc
    Two more cheese stores....
    https://www.youtube.com/watch?v=U0GjSzIPtgM
    3,856
    Dec 2010
    Toronto, Canada
    1,454
    HI.
    I haven't see those knives here so i ordered one from Ryanairspares. Thanks Grizzly
