    Nov 2005
    211
    solder fell into torch tip
    I was about to install plumbing for an icemaker when I noticed that some solder fell into the torch tip from a previous use. Has anyone else experienced this problem? What's the solution?
    Re: solder fell into torch tip
    Do you have another source of heat? If yes then hold blocked tip with open end down and apply heat to soften solder.
    Second option, get a drill bit to match the size of the torch opening and drill out the solder.
    Nov 2005
    211
    Thanks. I just bought another torch, melted the solder out, and got the install done.
    BTW, compression fittings are no good. I had one connection leak twice, and the two I currently have installed are leaking very slowly. What's the solution?
    Quote Originally Posted by star882
    What's inside the pipes ??
    If it's refrigerant then you shouldn't be using compression fittings.
    One problem with compression fittings is that people tend to overtighten them which damages the olives and seats.
    Aug 2005
    5,302
    The only two types of compression fittings I am aware of are; those for water which should should not be used, or those for hydraulic tubing. The hydraulic fittings work OK so long as you use the correct ferrules for the tubing.
    Nov 2005
    211
    Quote Originally Posted by Brian_UK
    It's water at line pressure.
    Oh, are flare fittings any better at sealing the connection?
  1. Torch
    By Peter_1 in forum Industrial
    Last Post: 17-07-2009, 04:53 PM
  2. SnAg solder (Stay-Brite): which fluxes are suitable?
    Last Post: 14-08-2005, 08:29 PM
  3. solder V Flare Driers
    By Latte in forum Technical Discussions
    Last Post: 23-05-2004, 09:22 AM
  4. the best torch
    By milton in forum Technical Discussions
    Last Post: 08-02-2004, 01:38 AM
  5. Tin/Antimony Solder
    By Robearbam in forum Fundamentals
    Last Post: 31-03-2003, 07:18 AM
