Thread: Thread size
    Nov 2008
    scotland
    69
    232
    10
    Thread size
    what is the standard threads used on gauges, flares, unions etc BSP UNF UNC AF or something else
    Dev
    Oct 2007
    manchester
    44
    5,707
    Re: Thread size
    sae on gauges hoses,flares-npt on fittings that screw onto components ie drain plugs- suction valves etc
    Nov 2008
    scotland
    69
    232
    10
    Re: Thread size
    Reason I ask is I ma after a new OFN guage I can get one with BSP outlet I cant tell what the thread that is tapped into the body so I was thinking about a direct couplingDev
    Oct 2007
    manchester
    44
    5,707
    Re: Thread size
    they do fittings at climate ctr- look through for 1/8 bsp to 1/4sae brass fitting-dont forget the ptfe or threadlock - climate ctr do nitro gauges with the 1/4 sae connection already fitted- dont get a 10 bar gauge -go for the 50 bar
    Nov 2008
    scotland
    69
    232
    10
    Re: Thread size
    Cheers IM I have a CC in Glasgow but they have to order stuff from downt south depot
    Dev
    Apr 2009
    Panacea, Florida
    81
    10
    Re: Thread size
    I recommend that anyone working in a mechanical trade obtain a copy of Machinery's Handbook. Everything you need to know about fasteners, thread standards, tubing and pipe sizes, wire and sheet metal gages, strength of materials, gear dimensions, and on and on is found in this one volume.
    Apr 2007
    30
    372
    Re: Thread size
    Theres an online company..SRW that do N2 replacement gauges http://www.srw.co.uk
