Thread: xarios 600(carrier refrer unit)
12-01-2011, 07:02 AM #1
whenever iam replacing this compressor (TM16)404gas which is company original compr, the compr got siezed, so kindly let me know which is the best compr will suit for this unit.
12-01-2011, 07:33 PM #2
Re: xarios 600(carrier refrer unit)
A TM16, the same as original is best.
12-01-2011, 07:47 PM #3
tm 16hd is as good as it gets but check oil sep on the carrier they are usually full of debris
13-01-2011, 07:32 AM #4
TM16XD is better still - extra duty version of the TM16.
Check that the fuse protecting the CPR bypass solenoid has been removed - most common cause of premature compressor failure on the 600s.
13-01-2011, 07:44 AM #5
To clarify the above Re: CPR solenoid fuse - If it is still in it's holder, take it out, walk ten paces from the truck and throw that fuse as far away from the unit as you can - you won't be needing it anymore.
The CPR bypass won't close by itself - it remains energised continuously, and will destroy compresssors when it goes through defrost. Simplest solution is to throw away the fuse.
13-01-2011, 09:43 PM #6
throwing things away on a carrier ? they spend years designing these items? sorry did i say years i meant miniutes / your quite right kiwi we have also started fitting mop valves to we have had many units with a standard valve tms are good but they all have limits
mitsubishi start up
By ballvalve in forum Air ConditioningReplies: 12Last Post: 21-01-2011, 06:12 PM -
Howden XRV204 compressor unit loosing alot of oil
By Tycho in forum NH3Replies: 26Last Post: 20-07-2010, 10:14 PM -
Airwell Florida - outside unit won't work - no error LED
By AndY1 in forum Air ConditioningReplies: 7Last Post: 17-06-2010, 08:11 AM -
New Toshiba unit won't start..?
By expat in forum Air ConditioningReplies: 14Last Post: 07-04-2008, 09:11 PM -
Off-line Mitsi VRF leaks!
By sinewave in forum Air ConditioningReplies: 8Last Post: 05-06-2007, 11:18 PM
