Thread: Single Flare vs Double Flare?
08-10-2010, 03:06 AM #1
Is double flare necessary for copper tube flares or is a single flare good enough?
08-10-2010, 07:51 AM #2
Re: Single Flare vs Double Flare?
Single flare used to be the only one with the old R22, R12, R502 and R11. But some of these newer refrigerants operate at higher pressures and have a smaller molecular size - hence the need for a double flare. Of course the double flare used to be used for brake lines on cars due to higher pressures.
To flare or not to flare?
By worthington in forum CommercialReplies: 15Last Post: 13-03-2010, 07:36 PM -
how to tell what kind of flare i need?
By cadillackid in forum Air ConditioningReplies: 10Last Post: 11-11-2009, 02:20 PM -
R22 Temp To Pressure Formula
By lwarren in forum Tools and CalculatorsReplies: 76Last Post: 29-11-2008, 08:46 PM -
Single compression vs two stage compression.
By Pawel_Wisnik in forum Technical DiscussionsReplies: 0Last Post: 07-09-2007, 01:53 PM -
Flare nuts
By Jase in forum Air ConditioningReplies: 17Last Post: 10-07-2005, 10:01 PM
