Thread: Pool Heat Pump
Threaded View
23-03-2010, 09:18 PM #6
Re: Pool Heat Pump
Sorry, yes it is HOT WATER HEAT PUMPS unit. Model 7GP60-3T.
The name plate on electrical panel says it's a Temperzone OSA405RKTV.
You were right about the low water flow. Pool cleaner has noted that water level keeps dropping below skim drains reducing water flow.
Will check later today for an improvement.
Design heat pump for a pool
By rolandh in forum Heat PumpsReplies: 10Last Post: 23-09-2010, 10:50 AM -
Addition of a heat pump to solar heating system
By rt29781 in forum Heat PumpsReplies: 24Last Post: 23-01-2010, 08:46 AM -
Pool heat pump water side diagram
By nike123 in forum Heat PumpsReplies: 23Last Post: 22-03-2009, 07:42 PM -
frostles heat pump
swimming pool heat pump
By Andy AC in forum The Trail of TearsReplies: 8Last Post: 26-08-2007, 04:02 PM
