    Willymcghee's Avatar
    Willymcghee Guest
    Exclamation Mycom Compressors - Metric or SAE
    My company has just recently started work on ammonia systems, specifically hockey rink ice systems. All the rinks we have are running mycom 8 cylinder compressors . Having mostly done commercial work only, i want to get a larger socket set (3/4 or 1 inch drive) and was wondering what sizes are required with mycoms? I know most of the work i do is in SAE but seeing as mycom is a japanese company, are they using metric parts on these compressors? It is very easy for me to get an SAE-only set, but i will have to order one in if i need to get a metric only, or combined metric/sae set.
    any help would be great
    Nov 2004
    China
    176
    Re: Mycom Compressors - Metric or SAE
    Metric bolts are used on all compressors manufactured after April 1979.
    3,362
    The only large socket needed for a mycom recip would be the flywheel .
    I would suggest 3/4" drive set to do job if you were to buy anything .
    Auckland
    74
    3,357
    37
    Bolts are metric, fittings BSPt
  1. Mycom relief valve issue?
    By Mojjee in forum Industrial
    Last Post: 15-05-2009, 03:26 AM
  2. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  3. FES screw compressors
    By negmy13 in forum Technical Speculations
    Last Post: 08-08-2008, 07:40 AM
  4. Do we have some expert in replacing compressors
    By Zahid in forum Air Conditioning
    Last Post: 01-07-2008, 07:59 AM
