    Feb 2005
    Aberdeen
    48
    168
    Daikin VRV 'master' set up
    Looking for some clarification on setting up the master controller.
    The system in question is a 2 pipe heat pump 'K' series serving 6 fan coils.
    At the moment, the master is located in one of the offices but the client wants the master controller to be sited in the m.d's office.
    Would I have to power down the VRV and all fan coils, then reset. Would this effectively reset the RC's and bring the system back to pre-commissioning stage or can I do some magic within the field settings
    regards,
    Jase
    Sep 2009
    Scotland
    374
    Re: Daikin VRV 'master' set up
    Quote Originally Posted by Jase View Post
    regards,
    Jase
    Hi Jase,
    That's an easy one
    Just locate the present heat/cool master controller, hold down the mode button until mode icon flashes, if you then press the mode button once on the controller you want as the new H/C master.
    Feb 2005
    Aberdeen
    48
    168
    Quote Originally Posted by VRVIII View Post
    Hi Jase,
    That's an easy one
    Great stuff; thanks for the prompt reply VRVIII
    Jase
    Mar 2007
    France
    236
    Hi Jase,
    That's an easy one
    Hi Jase
    If it doesn't work or if sometimes the unit "loose" master info i could give a special setting to go on
    rgds
    cool#9
    Feb 2005
    Aberdeen
    48
    168
    Quote Originally Posted by cool#9 View Post
    Hi Jase
    rgds
    cool#9
    Thanks for that cool#9. Not back to site yet, but if the 'swap' doesn't work then I will take you up on the special setting
  1. Daikin not working... many problems
    By stankovicv in forum Air Conditioning
    Last Post: 11-12-2010, 09:01 AM
  2. Daikin AC parts from UK
    By skel00 in forum Air Conditioning
    Last Post: 05-04-2009, 01:24 PM
  3. Fixing Daikin A3 Error
    By Stuffy in forum Air Conditioning
    Last Post: 27-03-2009, 06:02 AM
  4. Daikin Comp and inverter
    By WCC73 in forum Air Conditioning
    Last Post: 08-11-2008, 08:44 PM
  5. daikin vrv on/off remote signal trouble
    By coriolan in forum Air Conditioning
    Last Post: 09-06-2007, 11:27 AM
