Results 1 to 2 of 2
Thread: Fujitsu ASTA30LCC error code
29-01-2010, 01:14 AM #1
The outside unit (AOTR30LCT) has just stopped working, the inside unit (ASTRA30LCC) fan still operating and flashing lights. Operation (red) and timer (green) flash simultaneuosly 3 times then the red light continues another 5 times, then there is a pause and the sequence is repeated.
Your help is greatly appreciated!
aZ
29-01-2010, 07:06 AM #2
Re: Fujitsu ASTA30LCC error code
Figured it out - spoke with fujitsu technical help, code meant the unit was starved of voltage, then found out AGL were carring out maintenance in the area, the unit started up again this afternoon when they knocked off.
Fujitsu AOY90TPAMF
By andy c in forum Heat PumpsReplies: 6Last Post: 08-02-2010, 04:22 PM -
your opinons on fujitsu please
By acgibo in forum Air ConditioningReplies: 18Last Post: 26-08-2009, 05:06 PM -
fujitsu wall mount volt free relay
By mike live in forum Air ConditioningReplies: 3Last Post: 09-04-2009, 08:26 PM -
Fujitsu PCB
By gwilliamson in forum Air ConditioningReplies: 6Last Post: 10-09-2008, 10:27 PM -
Fujitsu or not?
By LRAC in forum Air ConditioningReplies: 14Last Post: 29-08-2007, 09:45 AM
