Results 1 to 8 of 8
    Jim Crooks's Avatar
    Jim Crooks Guest
    Carrier Genesis AL2 High Pressure alarm.
    Hello, I have a Carrier Genesis TM800 fridge trailer. The unit starts up o.k. but cuts out displaying the alarm code `HI PRESS`. I take this to mean high pressure. Any thoughts on how to solve this fault?
    klarenbeek's Avatar
    klarenbeek Guest
    Re: Carrier Genesis AL2 High Pressure alarm.
    It also could be low pressure or empty system
    Jul 2007
    Vancouver, Canada
    43
    97
    11
    post in the transport section
    Oct 2001
    Nottingham UK
    5,123
    42
    Thread moved
    I'm back on the Pale
    Jan 2008
    Canada
    579
    11
    If it was a low pressure issue, you would get "sys check" alarm.
    If all the belts are on, you will need to hook up gauges and see what is going on.
    Dec 2004
    U.K
    49
    517
    15
    [QUOTE=abbsnowman;165224]If it was a low pressure issue, you would get "sys check" alarm.
    If all the belts are on, you will need to hook up gauges and see what is going on.[QUOTE]
    Not always with the "sys check" depends how the parameters are set on the micro.
    Agree with the hook up the gauges bit though
    Dec 2004
    U.K
    49
    517
    15
    Could also be dodgy MP+ feed from the battery. Have seen that before.
    But as abbs says, if you put your gauges on and run the unit check if you have hi pressure first?
    Mar 2009
    Indiana, USA
    75
    10
    Quote Originally Posted by abbsnowman View Post
    The original Summit micro would not shut down or give an alarm on low suction pressure. When they first added the low suction pressure shut down the micro would show "HI PRESS". Ther are quite a few units out there like that. The newer revision micros will show the "SYS CHECK" alarm on low press. and Hi Press on High pressure. Hook some gauges up and it shouldn't be too hard to figure out which it is.
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. discharge pressure too high
    By zahar in forum Trouble Shooting
    Last Post: 16-02-2008, 08:58 PM
  3. High Deferential Oil Pressure Alarm
    By NNNNNN in forum Trouble Shooting
    Last Post: 24-12-2007, 01:06 PM
  4. TK basic micro-p features and functions
    By REEFER-TEK in forum Transport
    Last Post: 05-12-2007, 06:25 PM
  5. High Side Pressure is ...
    By SULTAN in forum Trouble Shooting
    Last Post: 14-08-2007, 12:53 PM
