    Nov 2008
    Indonesia
    44
    27
    The pipe of the split A/C installation
    How long minimal and the maximum of the pipe of the split A/C installation measurement 1 pk?
    Oct 2006
    1,848
    15
    Re: The pipe of the split A/C installation
    Quote Originally Posted by James priyono View Post
    Different systems have different lengths.
    There is no minimum but the maximum can
    vary from 15mtrs to 25 mtrs.
    Each system will have an instruction book and in that book you will find the maximum length and how much refrigerant you need to add over a certain amount.
    taz.
    Nov 2008
    Indonesia
    44
    27
    Oil will return to compressor, when long the pipe until 25 metre, taz?
    Jul 2007
    Australia
    44
    1,857
    14
    as per installation instructions. It varies, so the manufacturers tell you with their specific units in the install instructions. The bigger the unit, the longer the run allowed as a general rule.
    small 2kw units are normally 7m larger splits are up to 15m.
    As far as oil return, that's mainly an issue if the outdoor unit is above the indoor unit and the pipes are exceedingly long.
    Jun 2009
    East Anglia
    32
    204
    9
    Quote Originally Posted by taz24 View Post
    taz.
    Majority of systems do have a minimum pipe length as they come pre charged for X meters. this means if you get a back to back then you will have an over charged system!
    Some of the larger Daikin splits have a 5M minimum pipe run on them!
    Oct 2006
    1,848
    15
    Oil return can be a problem, also pressure drop over the longer distances, but a good quality, well installed system will work well as long as it is within the peramiters set by the manufacture.
    Quote Originally Posted by Clk320_Greg View Post
    Yep good point
    Some systems do have a minimum distance and I was being too general.
    Cheers taz.
  1. Pipe Installation
    By Rodders in forum Air Conditioning
    Last Post: 08-06-2009, 12:37 AM
  2. Installation question split system
    By jom2000 in forum Air Conditioning
    Last Post: 16-05-2009, 01:17 PM
  3. Mitsi split freezing HP pipe
    By Bat in forum Air Conditioning
    Last Post: 13-05-2008, 12:01 AM
  4. Q: Piping installation for Split Types
    By brianubaldo in forum Refrigerants
    Last Post: 30-04-2008, 02:23 PM
  5. Split System max pipe run length?
    By fridge doctor in forum Air Conditioning
    Last Post: 18-08-2007, 01:14 AM
