Results 1 to 2 of 2
    Apr 2007
    Pakistan
    15
    Ice build up on secondary evaporator coil
    while experimenting for on line mechanical dehumidification, I added another evaporator coil after origional evaporator coil which was giving outlet temperature 0f 20C but after no more than 20 mins Ice starts building on secondary evaporator and its compressor and refrigerant piping, I am wondering where did I go wrong. I think I should have had less number of fins per inch. What do my freind suggest.
    Best regards
    Split Croatia
    57
    6,151
    36
    Re: Ice build up on secondary evaporator coil
    Quote Originally Posted by hamidpia View Post
    Best regards
    We need pressures and temperatures to answer in meaningful way.
  1. Want to build a refrigerator-like cooling for my cpu
    By PeeWee in forum CPU Overclockers
    Last Post: 13-11-2008, 05:37 AM
  2. Secondary refrigerants
    By shills33 in forum Refrigerants
    Last Post: 21-10-2007, 09:46 PM
  3. Custom Refrigeration Build
    By pizza_boy in forum Commercial
    Last Post: 16-10-2007, 09:06 PM
  4. Secondary refrigerants (Brines)
    By Friobernal in forum Refrigerants
    Last Post: 18-10-2003, 01:09 PM
  5. I need to build two coldrooms
    By alpha in forum Technical Discussions
    Last Post: 14-10-2002, 01:31 AM
