Results 1 to 50 of 68
Threaded View
10-08-2009, 11:40 AM #14
Re: Mitsubishi ecodan Heatpump Boiler
I would say to all those considering ASHP for UK heating that they should serioulsy consider either the Hitachi Yutaki or the Sanyo CO2 Eco.
Both these units have had extensive R & D and pose the most realistic threat to traditional heating sources (boilers).
The Sanyo, in particular, is currently the only ASHP able to allow DHW storge at 65 C (using heatpump alone) at minus 20 C and has sufficient built in backup/redundancy heating in case everything turns to Rat S**T ! As it comes as a matched package, it's the one least likely to give aggro.
You get what you pay for!!
Mitsubishi vrv
By dakesojo in forum Air ConditioningReplies: 20Last Post: 22-09-2009, 01:04 PM -
does any 1 know HOW much cheaper it is to heat with AC heatpump compared to a boiler?
By kaspastarr in forum New TechnologiesReplies: 6Last Post: 11-12-2007, 11:38 PM -
Mitsubishi Light Truck Refrigeration
By Mastercool in forum TransportReplies: 2Last Post: 23-11-2007, 06:15 AM -
mitsubishi city multi fault code
By robin r33 gtr in forum Air ConditioningReplies: 5Last Post: 05-11-2007, 10:23 PM -
Mitsubishi compressor lock
By marc5180 in forum Air ConditioningReplies: 29Last Post: 08-10-2007, 05:48 PM
