Untitled
Carrier
2013
    Jul 2007
    Sg
    21
    Cooling tower piping design
    Context:
    Rectangular cross-flow cooling towers of about 200RT per fan, for water cooled chillers for commercial air-conditioning in a tropical climate.
    Some cross-flow cooling towers have piping arranged like in attached photo - incoming warm water pipe is submerged for a considerable length in the bottom basin, which seems sub-optimal.
    How much impact do you think this has on efficiency?
    I imagine there is a formula for estimating the heat flow from warm water thru a given area of PVC pipe into cooler water. Any pointers?
    Jan 2008
    alexandria egypt
    63
    3
    Smile Re: Cooling tower piping design
    hellow every one i am magdy akl from egypt my work mainly related to cooling towers and fans
    i work as advisor or cnsultant for sme contractors in my area.
    Jan 2008
    alexandria egypt
    63
    3
    did some one gave you any comment on this i wany to see it ?
    65
    9,409
    32
    Quote Originally Posted by kaon View Post
    Very little I would imagine, although I could be wrong
    If it had a major impact on performance then it would not have been designed/built that way.
    Do you have the make/model details?
    Brian - Torquay, Devon, UK
    I have to stop saying "how stupid can you be?" to my co-workers.
    They're starting to take it as a challenge...
    BASIC MAINTENANCE. If it doesn't move and it should then use WD40. If it moves but it shouldn't then use Duct Tape.
    65
    9,409
    32
    Quote Originally Posted by magdy akl View Post
    Could you not provide some useful information in reply??
    Jul 2007
    Sg
    21
    The photo is from a no-name tower, it is newly assembled, not in use yet.
    My sites have a few other cross flow towers of various makes.
    And I noticed that the Shinwa's have minimal submerged length, about 6 inches of vertical riser.
    And yet a no-name seemingly under-performing tower has lots of submerged horizontal runs. Sticking a thermometer probe into the basin at various points showed more than 1 degree C rise near the pipes.
    A probe stuck into drips in the infill from outside might read 25C while a probe stuck in the basin might read 27C. I want to measure the temperature of water that is just dripping into the basin, I would need to be inside the CT while it is running, and use a little cup...
    Jun 2005
    California
    397
    8
    looks to me like it's piped backwards
    look here to see how a cross flow is normally piped
    http://en.wikipedia.org/wiki/Cooling_tower#HVAC
  1. large refrigeration plant cooling tower issue
    Last Post: 25-03-2007, 01:35 PM
  2. Cooling Tower Design
    By jteixiera in forum Tools and Calculators
    Last Post: 31-01-2006, 01:23 AM
  3. cooling tower without fillings
    Last Post: 27-12-2005, 01:55 AM
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  5. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
