Results 1 to 28 of 28
    Mar 2012
    54
    12
    Samsung RSA1DHMH
    Hello folks
    side by side fridge / freezer with water/ icemaker
    i need some info on how to adjust the freezer door, the bottom right hand corner is not sealing causing frost in the freezer. the unit is level & vertical. Aquired from mother inlaw delivered by removal company. Also is it normal on this style of freezer for the temp to vary on it's own or is this due to the door problem?
    thanks
    manchester
    5,639
    Re: Samsung RSA1DHMH
    tip it back and get screwdriver on it,otherwise a hammer- tonto is ur man for a more technical answer
    Mar 2012
    54
    12
    guess i'll have to wait for Tonto then
    manchester
    5,639
    found a spares site
    http://www.4mysamsung.co.uk/cgi-bin/...ung%20RSA1DHMH Hinge&brand=Samsung&model=RSA1DHMH&path=111066&part=Hinge
    Jul 2006
    norfolk
    737
    was the doors removed when the fridge was moved and installed? have you checked the door seals to make sure no gaps and sealing correctly, as there is no real adjustment on these doors, just three bolts at top to hold in place.. if not cooling as it should then 1st thing put it into error code mode and see if it shows any faults
    Feb 2012
    Bolivia
    270
    14
    I don’t know your model, normally household freezers have non-adjustable hinges.
    What you should do is change the door gasket.
    You may temporarily fix it inflating the seal injecting silicone beneath, but it won’t last.
    You can check the seal pushing a thin sheet of paper. If it goes in between, the gasket is not closing the gap.
    The gap in the door could affect the temperature for short periods. On long periods it could be the thermostat.
    A malfunctioning thermostat can also produce frost inside.
    Jul 2006
    norfolk
    737
    there no thermostats on these only senors and you cant just change door seal you have to replace whole door
    manchester
    5,639
    its the freezer side so a bit of frost is a good sign!
    Quote Originally Posted by aramis View Post
    Mar 2012
    54
    12
    Quote Originally Posted by tonto33 View Post
    the doors were removed & there is a gap between seal & frame of about 3-4 MM for about 18 inches from the bottom of the door up.i can feel the cold air coming out. i have removed the bottom drawer to make sure it's not that causing the prob.
    Jul 2006
    norfolk
    737
    take door off again and refit make sure door fits tight before doing bolts up
    3,853
    Is the floor level? If not it can twist the cabinet and the door won't seal as its not twisted too... Usually theres some screwy iny outy feet, might have been fine till it was filled up with food as the increased weight has an effect.
    Mar 2012
    54
    12
    this sounds like the best option, will have to whip out me socket set
    Mar 2012
    54
    12
    fridge is level & vertical
    manchester
    5,639
    check theres no play in the door when its open to ensure theres no nylon inserts missing-as monkey spanners says slackening off the bracket will give you some movement to possibly align
    Mar 2012
    54
    12
    door is solid when open, & there's ver little movement with the top bracket loose .
    there is a screw on the lower hinge but very difficult to get to to adjust
    manchester
    5,639
    did they take the doors off and the brackets- if so did they cross the fridge door brackets with the freezer brackets ?- it would be easier to check it if you unplug it . could take the milk /bottles out- pull the fridge forward about 18inch and tilt it back so it rests against the wall and put something underneath to stop it crushing ur fingers
    Feb 2012
    Bolivia
    270
    14
    Not in nofrost ... at least not permanently.
    I inflated my door gasket with silicone and you can't tell it's not original work ... ok, ok I know someday it may come to bite me where it hurts! )
    Mar 2012
    54
    12
    i was at work when they dropped it of so don't know other than "they took the doors off". the fridge door has a height adjuster screw at the bottom , freezer door is just bolted onto the housing
    does anyone have a service manual? or point me in the right direction. no point connecting the water up for ice till i get this door sorted
    manchester
    5,639
    have you reported the problem to the removal men that since delivering it, theyve f****d it and put the ball in their court so to speak?-ive searched and cannot find anything
    Mar 2012
    54
    12
    Hmm hadn't thought of that one, mother in laws stuff was put into storage & paid 'em 40 quid cash to bring it here.
    might have to find a Samsung dealer , but thats gonna cost tons
    manchester
    5,639
    not if you live in norfolk!
    Mar 2012
    54
    12
    is it poss the door is twisted / warped , then were looking at a new door.......YIKES
  23. #23
    Mar 2012
    54
    12
    what about the white rose county?
  24. #24
    Jul 2006
    norfolk
    737
    where bouts are you
  25. #25
    Mar 2012
    54
    12
    check yer messages
  26. #26
    Jul 2006
    norfolk
    737
    can get someone there monday to sort
  27. #27
    Mar 2012
    54
    12
    thanks Tonto. no idea how but it's sorted itself out. seals perfectly & temp is stable at -18
    & frost build up has gone. will get water connected up over the weekend
    effing weird
  28. #28
    3,853
    Quote Originally Posted by Spanjo View Post
    effing weird
    http://www.youtube.com/watch?v=CGeT5cutXgU
    MS
