31-03-2008, 05:55 PM #1
Wirlpool FF Issue - fridge warm, freezer cool
Hi guys,
we've got a problem with the Wirlpool FF (85017471558 ) at my pad. This is a " total non-frost unit !!" and air from teh freezer comp is cirulated into teh fridge comp. In essence the problems are:
* the freezer compartment freezes up after a few days.
* the pump and circulation fan are on constantly
* I've defrosted, checked the thermostat and the thermisters and they seem ok
I've notice that when the freezer comp and fridge compartment doors are open, air circulates perfectly. Close the freezer door and the cirulation stops. Close both and nothing cirulates. This is a really stupid question, but could this be due to the door seals or do we need to regas the unit.
Look forward to hearinhg from you guys.
Keith
31-03-2008, 07:38 PM #2
Re: Wirlpool FF Issue - fridge warm, freezer cool
[QUOTE=kinetic100;99670]Hi guys,
Hi , kinetik
I send to you electrical diagram and NTC temperature chart. If NTC resistence value "migrate " with few ohms , - 22 deg.C is , for electronic module , -2 deg , for example and all is wrong inside.
Best regards
Gramcor
31-03-2008, 08:05 PM #3
Keith, welcome...we hope we can help you, but I think we will need a bit more info from you...
Is it a ARC7472/IX (850174715058)?....I cannot find an exact match to your model
What are the temperatures of the Freezer and Fridge compartments.?
You say the freezer compartment freezes up....do you mean the evaporator at the rear?
It sounds as though you have a defrost problem....or possibly a door seal is not sealing or the door is not closing properly.
Have you checked the defrost heater and circuit? There should be an overtemp cutout in circuit.
I would expect the internal fan to run except when on defrost. The compressor might run 18hrs....is this unit freestanding or built in?....can it get rid of the heat? Both will result in the unit running longer.
How did you defrost and for how long?...A lot of problems associated with ice build up in the air ducts to the fridge require 48hrs to fully defrost.
Return air duct blocked?
01-04-2008, 10:54 AM #4
01-04-2008, 11:09 AM #5
[quote=Electrocoolman;99690]Keith, welcome...we hope we can help you, but I think we will need a bit more info from you...
Hi Electrocoolman,
thanks for your reply just tio answer your questions so far:
>Yes it is an ARC7472/IX
> 15 Degree C in Fridge and -18 in Freezer, with Ice build up at the front next some of the seals.
> In a sense yes, the whole side and and top have a thick layer of ice from teh air circulating. I also end up taking all the panel out and defrosting the evapouration equipment. I think also ice builds up behind the panel where the fan is and pushes this out, so the fan is not aligned to the tube tup to the fride comp.
> I though it is this because I ran little experiement. I put a small tube on one of the seals when closing the freezer comp. 20 mins later the fridge compartment had dropped 8 degrees C. Which lead on to the answer to your next question.
> I think this isn't working correctly as nothing has shut off correctly. I left the said experiment running for 3 hours and the fridge comp reached 3 degrees C and freezer -20 degrees C
>At no point does it appear to have shut off. I'm goign to have a look at the drain in the freezer comp this morning.
> I have to admit, with a full fridge and freezer, we only defrosted for 6 hours (with help of the neighbours !)
>No, it didn't appear so. I took the internal facia for controls in the fridge out of situ and with a tube at the bottom to catch fluid, poured hot water down. At no point did it appear that it was blocked as the water appear to flow the same each time.
Best regards,
Keith
01-04-2008, 06:25 PM #6
Just to follow up exploratory work. I have now done the " boiling water down the drainage tube treatment" which seems to be a common approach when there are cooling sensor issues ( it seems to have saved some people teh cost of a new unit anyway). Just to report, the fridge definately for 2 hours stopped cooling when it reached the appropriate temperature.
N.B cannot do a full defrost as missus and my daughter are ill.....
02-04-2008, 01:36 AM #7
Hopefully not food poisoning ? !!
fridge warm freezer cold?
By babsnsarah in forum DomesticReplies: 25Last Post: 30-04-2011, 04:24 PM -
BOSCH Fridge/Freezer - fridge wont cool....freezer fine
By andy_lanc in forum DomesticReplies: 6Last Post: 25-10-2010, 01:25 PM -
crazy 3rd-world idea: aircon from small fridge
By lsemprini in forum FundamentalsReplies: 71Last Post: 29-05-2008, 01:10 AM -
Zanussi zebf 249n fridge warm, freezer cold
By davemar in forum DomesticReplies: 4Last Post: 18-03-2008, 08:58 PM -
Zanussi - fridge is warm but freezer is cold.
By Bob Ball in forum Trouble ShootingReplies: 2Last Post: 11-02-2007, 04:59 PM
