    Kevin08's Avatar
    Kevin08 Guest
    New Member - London Area.
    Hi Everybody,
    Im currently doing an electrical course at college but really want to get into the air conditiong trade. If anybody could explain to me in a very basic form how an air conditioning system works it would be greatly be appreciated.
    Thanks.
    70
    4,700
    47
    Re: New Member - London Area.
    Quote Originally Posted by Kevin08 View Post
    Hi Everybody,
    Thanks.
    I have not got enough space or typing experience to fulfil your request.
    But I will see if I have any basic info I can forward to you.
    Kevin08's Avatar
    Kevin08 Guest
    All I want is basically a simple explanation of how the simplist air conditioning split works.
    OoOoh also just noticed your location, I have family down in Somerset.
    Also any informatrion would be greatly recieved, thanks.
    Split Croatia
    6,151
    Hi Everybody,
    Thanks.
    Start with looking at this:
    http://www.refrigeration-engineer.co...ad.php?t=12064
    Then, ask questions.
    Kevin08's Avatar
    Kevin08 Guest
    Thanks, I'll have a look now.
    Basic description of air cooling system, not air conditioning that's something else.
    AC works on the same principle as your refrigerator.
    Quick gas law - temperature increases with pressure, likewise, temperature falls with pressure.
    We start with a compressor, this sucks in refrigerant vapour and compresses it to a higher pressure and temperature. The hot vapour travels through a condenser (black pipe coil back of fridge) where the hot vapour cools by giving up heat to the surrounding air.
    As the vapour cools it 'condenses' into a high pressure liquid. The high pressure liquid then passes through a restriction device which causes the pressure to fall (a bit like a resistor dropping the voltage); as the pressure falls then so does the temperature.
    The low pressure liquid now passes through the evaporator (ice box in the fridge) where it removes heat from the surrounding area and in doing so vapourises the liquid refrigerant back to a vapour/gas.
    The vapour is sucked back to the compressor to start all over again.
    Replace the ice box with the air cooling coil with air blown over it and there you have an AC unit.
    70
    4,700
    47
    Nothing wrong with your typing Brian.
    Nice one!
    Tampa, Florida U.S.A
    590
    Nice and concise,, good work Brian.
  1. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  2. Work In London
    By timholmes204 in forum Supermarket Refrigeration
    Last Post: 12-06-2006, 08:44 AM
  3. Apprenticeships in London
    By Danz in forum Training
    Last Post: 28-03-2006, 02:53 PM
  4. London rates
    By Abe in forum Air Conditioning
    Last Post: 26-05-2004, 10:33 PM
