Thread: head master inquiry
21-02-2008, 02:45 AM #1
head master inquiry
I was going thru some of our refrigeration parts at our warehouse and ran across a sporlan lac-4 100/180ds head master. i believe it can be used for r134/r12 or r-22 0r 404a. from what i gathered you break the process tube off for 100psi operation. any body used 1 of these? are they reliable?
21-02-2008, 09:23 PM #2
Re: head master inquiry
TGraham,
You are correct, the LAC-4-DS is a one time adjustable valve for either high or low pressure gas. The setting of 100 is good for 12/134A and 180 is good for 22/502.
Here are the links to the Parker/Sporlan site which will supply more details.
Install & Service: http://www.parker.com/literature/Lit...090/SD-134.pdf
Charging: http://www.parker.com/literature/Lit...90/90-30-1.pdf
Powell
21-02-2008, 11:49 PM #3
Thanks Powell I am new to Re site and appreciate your input and the links you provided
22-02-2008, 04:01 AM #4
Ooo you can send it to me for a therough test run lol, they're good, sporland tends to make good kit.
Prestcold head bolt torque?
By monkey spanners in forum Technical DiscussionsReplies: 6Last Post: 21-01-2008, 08:03 PM -
Refrigerated display cabinet, low head pressure
By expat in forum CommercialReplies: 10Last Post: 11-12-2007, 09:07 AM -
MV600 head pressure trip (ghost)
By andre_fridge in forum Technical DiscussionsReplies: 9Last Post: 28-01-2006, 02:16 PM -
Portable chiller shutting down on High Head
By Arkma in forum Trouble ShootingReplies: 10Last Post: 17-06-2005, 01:24 PM
