26-11-2007, 06:16 AM #1
De superheater in Air Cooled Chiller
Can any one please tell how doees a De superheater in air cooled chiller work? What are its advantages.
26-11-2007, 07:38 PM #2
Re: De superheater in Air Cooled Chiller
Desuperheater removes heat from superheated refrigerant gas after compression, but it does not remove enough heat to cause condensation of the refrigerant. The advantage is the relatively high temperature of the removed heat, the disadvantage is that the desuperheater is normally limited to 5-25% of total heat rejection.
26-11-2007, 09:02 PM #3
As NoNickName stated the purpose of the desuperheater is to remove temperature from the gas stream.
NoNickName, nice to see you around here. How is your work progressing?If all else fails, ask for help.
27-11-2007, 12:03 PM #4
What is the advantage of de-superheating the hot gas when it would otherwise be cooled by air on the air cooled condenser any way especially when both heat is to be dissipated to the ambient air. I am assuming that the de-superheater would be in operation when the chiller is operated to cool.
27-11-2007, 12:20 PM #5
Hi, Rabindra
Originally Posted by NoNickName
Best regards, Josip
28-11-2007, 12:13 AM #6
The advantage is the higher temperature than condensing temperature. So, if you need to recover heat at e.g. 70°C you can't use a condenser. You need a desuperheater.
And for US Iceman, I'm back in town. Leaving the new job for a refrigeration compressors manufacturing company. I'll be around more and more frequently.
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
Trane Rtaa 213 Air Cooled Liquid Chiller
By ahamedkyana in forum Trouble ShootingReplies: 13Last Post: 08-07-2008, 10:27 AM -
Water Chiller
By lana in forum Technical SpeculationsReplies: 20Last Post: 23-06-2007, 01:19 AM -
Trane Air Cooled Chiller
By iceman007 in forum Trouble ShootingReplies: 26Last Post: 11-04-2007, 08:30 PM -
Mcquay PES Flooded Water Cooled Screw Chiller
By Brian in forum Technical SpeculationsReplies: 4Last Post: 05-07-2006, 09:43 PM
