Thread: R-value conversion
02-01-2003, 06:39 PM #1
R-value conversion
Trying to convert the following from Europe into an R-value which is comparable to American figures:
R = [(0.004 mq * C°) / W]
Any idea how to go about it?
02-01-2003, 08:44 PM #2
Try breaking your formula down into their own units and convert each entity individually via dimensional analysis or you may want to refer to various handbooks.
02-01-2003, 10:10 PM #3
to convert to American is as follows:
From To Divide by
W/ (m) (k) (Btu) (in.)/ (hr) (ft2) (R) 0.1442285
The 2 after ft is squared, must set my keyboard up properly.
Hope this helps Regards. Andy.
02-01-2003, 10:58 PM #4
W/m-K is a thermal conductance unit of measurement.
R values are thermal resistance, and in IP units are typically °F-hr/Btu. Converting from °C/W to °F-hr/Btu:
1 Watt = 3.412 Btu/hr
1C° = 1.8F°
conversion factor: 1.8/3.412 = 0.5275Prof Sporlan
Free conversion software I use
By Peter_1 in forum Tools and CalculatorsReplies: 13Last Post: 23-12-2010, 11:57 AM -
Pressure to Temperature Conversion
By cryptojoe in forum Technical SpeculationsReplies: 5Last Post: 13-04-2010, 12:42 PM -
R-22 conversion
By reefermadness in forum TransportReplies: 25Last Post: 24-08-2009, 02:12 AM -
Propane Refrigerator Conversion
By zolar1 in forum RefrigerantsReplies: 26Last Post: 04-02-2007, 03:42 AM -
R12 to R134A conversion
By northern-tech in forum CommercialReplies: 8Last Post: 26-06-2006, 06:24 PM
