Results 1 to 10 of 10
Thread: Ammonia Plant
02-01-2003, 04:31 PM #1
Ammonia Plant
We are currently back engineering a Plant working on Ammonia after a Fire. The HSE are involved and we have been questioned regarding our water neutralisation method for small service jobs such as checking/ repairing Danfos PM Valves.
Has anyone out there come across a small recovery set similar to that used on *****s and the like.
Just a thought.
31-12-2006, 11:38 AM #2
Re: Ammonia Plant
A small portable (***** type) recovery / transfer unit for liquid and vapour nh3 is avaiable from Polar in doncaster england on this number : - 01302 751 253
31-12-2006, 05:02 PM #3
31-12-2006, 05:03 PM #4
Re: Ammonia Plant
Originally Posted by kevinxt
31-12-2006, 10:48 PM #5
Re: Ammonia Plant
I'm not sure whether there will be any response from Kevinxt.
His last post, above, was almost 4 years ago so he doesn't seem a regular visitor I'm afraid.Brian - Newton Abbot, Devon, UK
01-01-2007, 01:07 AM #6
Re: Ammonia Plant
Right you are Brian. Just goes to show a person should read all of the information, not just part of it.
01-01-2007, 01:42 AM #7
Re: Ammonia Plant
Do we have a make and Model Number available for these recovery machines? Those of us on the other side of the might have a use for them.
01-01-2007, 08:16 PM #8
Re: Ammonia Plant
Yes the Recovery / transfer machine Is A Polar Pumps Model OLE70 nh3 (oiless/electric 70Kg per hour Liquid 25Kg Vapour) Maintainance free, Auto Reset Hi Pressure cut out and dual voltage as standard also 15Kg Gross Weight. Simple to use I.E. in - out- On - Off Contact Them on Tel :01302 751 253
Fax: 01302 751 254
01-01-2007, 11:31 PM #9
04-01-2007, 08:54 AM #10
Re: Ammonia Plant
the ole 70 nh3 is a development within the last 3 years and the web site is ancient so yes the OLE 70 is for ammonia liquid and vapour thank you
contaminants in ammonia systems
By Johnny Rod in forum RefrigerantsReplies: 29Last Post: 17-10-2011, 05:26 PM -
Want to be trained as an ammonia operator
By Randy Williams in forum NH3Replies: 7Last Post: 26-11-2008, 08:15 PM -
New Ammonia Certification in United States
By JerrydNH3 in forum NH3Replies: 11Last Post: 15-08-2006, 03:10 PM -
Ammonia Gauges?
By nomiracle in forum FundamentalsReplies: 12Last Post: 26-07-2005, 02:19 AM -
Questions Ammonia evaporators
By Friobernal in forum FundamentalsReplies: 5Last Post: 25-03-2003, 10:36 AM
