    mtoto's Avatar
    mtoto Guest
    motor horse power
    Is it possible to determine the Horse Power of a motor by measuring a resistance across the windings??
    I know we can calculate volts*amps=kva*power factor =KW of motor input. But how about just testing the windings??
    Dec 2001
    Canada
    70
    52
    In a word, "No".
    Dec 2001
    Cincinnati, Ohio, USA
    63
    258
    I used to work in an electrical rewind shop when I was in the Navy. The power was determined by the number of coild, the number of turns of wire in each winding, the size of the coils, and the voltage applied.
    Gibson is essentially correct. you can't determine the information desired without knowing the design of the item.
    May 2002
    TN
    124
    You can get an idea, but your meter is measuring DC resistance. AC reactance will be between 4 and 6 times that value most of the time. I have seen AC reactance to be 10 times the DC resistance on high torque motors.
    Feb 2001
    Tampa Florida
    1,076
    I would dearly love to see a table of values developed on that, superheat.
  1. Replies: 2
    Last Post: 01-01-2011, 03:57 AM
  2. Daikin KRP2A61 Card Power consumption
    By EddieC in forum Air Conditioning
    Last Post: 19-08-2006, 04:08 PM
  3. what is a capacitor power pack ?
    By Bahaaeldeen in forum Air Conditioning
    Last Post: 11-05-2006, 12:56 PM
  4. NEW 3-Phase IGBT Inverter Power IC
    By theberes in forum New Technologies
    Last Post: 01-03-2004, 01:10 AM
  5. EEV's and their usefullness for low power applications
    By DaBit in forum New Technologies
    Last Post: 18-08-2003, 09:11 AM
