Results 1 to 20 of 20
Thread: Vacuum pumps
16-07-2006, 08:38 PM #1
Vacuum pumps
This pump is sold by Ryan Aircon Supplies who advertise on this site.
http://www.ryanairconspares.com/prod...ufacturers_id/
Anyone use this pump or who can comment on it?
16-07-2006, 09:41 PM #2
Re: Vacuum pumps
looks like the Yellow Jacket we use
http://www.sca-australia.com.au/cata...cuum_pumps.phpIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
16-07-2006, 10:33 PM #3
Re: Vacuum pumps
You're getting more and more involved in your project now Mick, enjoy These pumps are ok but if and when you buy one don't forget to get the oil for it as well.
16-07-2006, 11:03 PM #4
Re: Vacuum pumps
Originally Posted by Brian_UK
16-07-2006, 11:32 PM #5
Re: Vacuum pumps
I'm not sure about the quality of the gauges fitted to those pumps so can't really comment - however - in most cases you will find a recommendation to fit the vacuum gauge to the item being evacuated and not at the pump.
A good quality electronic vacuum gauge will set you back about £125.Brian - Newton Abbot, Devon, UK
17-07-2006, 07:11 AM #6
Re: Vacuum pumps
I prefer an Edwards medical quality torr gauge, quite expensive but mine is over 10 years old now, a mate of mine is on his third electronic gauge in 5 years.
17-07-2006, 09:27 PM #7
Re: Vacuum pumps
18-07-2006, 07:50 AM #8
Re: Vacuum pumps
Originally Posted by Andy
But could you explain the reason for this, assuming pressure througout the system must be pretty equal.
The only thing I can think is to avoid fluctuations on readings due to proximity of the pump?
18-07-2006, 11:58 AM #9
Re: Vacuum pumps
i think Andy meant whilst in the process of evacuation, not once all valves are then closed, it woulndn't matter where you place gauge then, have to agree BOC Edwards do great mechanical gauge, electronic are troublesome, the price would suggest otherwise though.
18-07-2006, 12:02 PM #10
Re: Vacuum pumps
origional point raised; I too have had above vacuum pump for 7 years+ regular oil chnges still going strong never let me down, allthough thinking bout it have two robinairs about the same age and they aint give me grief either
18-07-2006, 10:53 PM #11
Re: Vacuum pumps
Originally Posted by bebad
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=020&item=300005689498
25-07-2006, 02:36 PM #12
Re: Vacuum pumps
Is there any disadvantage other than evacuation speed from buying a 1/6 HP two stage pump vs a 1/3 HP two stage pump? I'm looking at inexpensive units on eBay. Being practical about the time involved, if one will leaves the pump evacuating the system overnight, is there any performance difference at all? The smaller unit is lots cheaper and lighter.
25-07-2006, 11:39 PM #13
Re: Vacuum pumps
Originally Posted by Larry2
1 stage pumps are also available,
What is the benefit of a 2 stage pump over a 1 stage pump?
26-07-2006, 01:23 AM #14
Re: Vacuum pumps
Originally Posted by mick2me
The pumps I used to use were two stage with a gas ballast. When you first start the evacuation, you open the gas ballast valve to quickly pull down the vacuum in the system.
After the vacuum gets down to some value (don't remember at the present), the gas ballast valve is closed.
Then the pump is running full out.
I believe the two stage pumps will pull a deeper vacuum quicker.
26-07-2006, 10:09 AM #15
Re: Vacuum pumps
Yes 2 stage vac pumps pull down to a deeper vacuum. I was told that if you use a large CFM vac pump on a small system it can pull down a vac so fast that any vapour in the system freezes due to the deep vac.
26-07-2006, 10:38 AM #16
Re: Vacuum pumps
Originally Posted by Mickvee
26-07-2006, 11:15 AM #17
Re: Vacuum pumps
JAGw
26-07-2006, 04:42 PM #18
Re: Vacuum pumps
[QUOTEHow do you remove this Vac gauge without a spill or contamination?
JAGw][/QUOTE]
One way would be to add some refrigerant pressure from the other end of the system until you had somewhat above 0 PSIG. Then detach the gauge from the low loss fitting and apply the brass cap. Minimal loss and no contamination.
26-07-2006, 04:53 PM #19
Re: Vacuum pumps
Hi as I work on Ammonia systems the way that I use, is to fit a service valve before the vacuum gauge, That way you can shut the valve and remove the gauge and then cap the outlet.
Arthur
28-07-2006, 03:56 PM #20
Re: Vacuum pumps
Does anyone have experience with FJC vacuum pumps? I'm considering purchase of this small two stage unit.
http://www.thetoolwarehouse.net/shop/FJC-6908.html
Recovery and vacuum equipment
By Larry2 in forum FundamentalsReplies: 2Last Post: 19-07-2006, 12:16 AM -
Can I leave a system in a vacuum overnite?
By kengineering in forum Technical DiscussionsReplies: 15Last Post: 17-05-2006, 03:03 PM -
problems with ice slurry production by spraying water in a vacuum chamber
By goodluck99 in forum Trouble ShootingReplies: 6Last Post: 16-04-2006, 01:27 AM -
Heat Pumps
By US Iceman in forum IndustrialReplies: 11Last Post: 14-04-2006, 07:29 PM -
All you ever wanted to know about vacuum pumps
By star882 in forum Refrigeration BooksReplies: 0Last Post: 27-12-2005, 01:44 AM
