    flasah's Avatar
    flasah Guest
    What kind of valve is this?
    Can anyone identify this valve? It has three staggered threaded 1/4" ports, a knob that pulls in and out, and is plugged at the other end. The body is 3" long and 1 1/2" in diameter. There are five of these used for manual capacity contol on a Grasso compressor.
    Patrick
    Jun 2001
    N.Ireland
    1,630
    Re: What kind of valve is this?
    Hi Flasah
    I can tell you what it is but I can't tell you where to get it except Grasso.
    Its a three port hydralic diverter valve.
    You can repalce it with any valve manufacturer provided the valve is compatible with the refrigerant and the oil being used. The pressure shouldn't be a problem say 8.5 bar on a grasso, much lower than 120 bar on a hydralic system
    Kiind Regards Andy
    flasah's Avatar
    flasah Guest
    Andy,
    Thanks for the help. Now, hopefully, I'll be able to find where to get one.
    Patrick
  1. Scotsman commercial H2O inlet valve
    By fullcourt in forum Trouble Shooting
    Last Post: 25-04-2006, 11:41 PM
  2. Need a correctly sized valve
    By Abe in forum Commercial
    Last Post: 26-10-2005, 08:42 PM
  3. pressure drop between expansion valve and distributor
    By aygul in forum Technical Speculations
    Last Post: 22-01-2004, 09:47 AM
  4. Replies: 5
    Last Post: 16-10-2002, 12:38 AM
  5. Valve "Hunting"
    By Abe in forum Trouble Shooting
    Last Post: 21-01-2002, 12:29 AM
