Results 1 to 10 of 10
14-06-2006, 06:15 AM #1
how to calculate cooling time needed?
I have a question like bellow:
At the beginning, the room temperature and ambient temparature is the same, for example ( 35℃ DB, 70%RH), I want 27℃ DB, 60% inside finally.
the given air conditioner is 10 Kw for example, the thermo transfer coeficient K is 2.4w/m2.c.
let's say the room size is 3m*3m*3m
how to calculate the necessary time?
14-06-2006, 08:23 AM #2
Re: how to calculate cooling time needed?
the time need is : cooling capacity /air volum*delta enthalpy if your cooling capaciy can balance the room heat load
14-06-2006, 10:58 AM #3
Originally Posted by Lc_shi
14-06-2006, 08:54 PM #4
27143721,
most people will reply like this, but, don't forget,
14-06-2006, 09:00 PM #5
Originally Posted by US Iceman
It's a test?
14-06-2006, 09:02 PM #6
The method also seems strangely familar to someone that you might know wambat.
15-06-2006, 02:27 AM #7
I think maybe some people know better.
by the way, what's the meaning of "wambat"?
15-06-2006, 04:07 AM #8
27143721
what you say is right,it's dynamical processbut you can estimate it by easier method at many occasions. Of course if it's a precision lab,you need to carefully calculate it and have a test to confirm it finally.
What I mentioned is only a clue for you; may be you can use some simulation program to run it
regards
15-06-2006, 06:23 AM #9
15-06-2006, 06:54 AM #10
coolpack is able to do this job. have a try
Heating / Cooling Control
By walden in forum ElectricalReplies: 11Last Post: 16-04-2006, 01:20 PM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM -
Time delay for multi compressors
By iceman007 in forum Air ConditioningReplies: 5Last Post: 06-11-2004, 08:05 AM -
Regulation of cooling capacity
By npaisnel in forum DomesticReplies: 13Last Post: 08-02-2002, 11:22 PM
