    Dec 2004
    Weihai,China
    800
    R718 as refrigerant
    Hi sirs
    I randomly found an article for R718 water chiller. It's an interesting topic. R718 is H2o. Use water to produce chilled water. Very good. Who know this machine? Is it available for practical use? welcome input
    regards
    LC
    Aug 2005
    iraq
    67
    130
    Re: R718 as refrigerant
    dear sir
    would you provide us with more detales
    please send internet site of the company who produce this kind of chiller
    regards
    afeef
    5,667
    Aug 2001
    1,046
    You are thinking of a Lithium Bromide / Water Absorption chiller. They've been around for most of the last century, and are still made. They tend to be very large capacity, and can capitalise on large quantities of waste heat.
    By today's criteria they have a poor efficiency profile, because of thier high reliance on direct-fired carbon fuels, but still installed. Usually they are around 1 - 1. 5mW (3-4000TR).
    I worked on a few in the 70s. The smallest one I ever commissioned was a Japanese Carrier 16JB that was considered a table-top model at 100 TR, (about 350 kW).
    LiBro is the absorbent and water is the refrigerant. The system is kept at a vacuum to promote evaporation temperatures in the order of 5 Celsius.
    The other variant of the absorption process is a slightly different technique; it uses water and ammonia. In this case the ammonia is the refrigerant and water is the absorbent.
    ________
    vapir oxygen
    Mar 2006
    Merate (LC) - Italy
    2,549
    Not quite. R718 can be used in a phase change chiller as the refrigerant, bu evaporating and compressing water vapour exacty as any other refrigerant.
    Applications are in the range of high evaporation temperature (+20/35°C).
    Considerations must be applied for the high expansion ratio after evaporation and low exponent, that would lead to use turbine compressors (high flow, low compression ratio).
    Liquid separation is also an issue.
    Jun 2005
    S****horpe
    135
    http://www.refrigeration-engineer.co...ead.php?t=4124
    Not sure about what you saw, LC but in principle water would be great, it's a lot like ammonia i.e. high latent heat, large amount of vapour for the liquid volume.
    It's a lovely day to pump some gas
    kren's Avatar
    kren Guest
    There are developments of compression chillers using water as refrigerant. Several machines have been in the field test in the recent years. (Megawatt class, I guess). However, the compressor is very special and expensive. Therefore, economics is an issue.
    Mar 2004
    Denmark
    65
    Just went back from technical shool.R178 as refrigerant is
    a very interesting problem. Here in Denmark LEGO has buildt
    a system with water vapour compressor, they use this to
    cool down diff. machinery.
    Here in Denmark ther has been started a project to develop
    water vapour compressors.
    By the way a have a PDF file 1.8 Mb. 260 pages concerning
    water vapour compressors, so if anyone is interested just
    mail to me.
    Best regards
    Carlo Hansen
    Mar 2004
    Denmark
    65
    Hi again
    Just forget to set in this link.
    http://st-div.web.cern.ch/st-div/wor...ogy/JacekK.pdf
    Best regards
    Carlo Hansen
    Mar 2006
    India
    80
    70
    [ Will be geatful,if you can mail me the PDF file 1.8 Mb. 260 pages concerning water vapour compressors, I am interested.
    Myemail :dhaliwals@gmail.com:
    Best regards
    Dhaliwal
    Dec 2004
    Weihai,China
    800
    I think you can download it by the link
    rgds
    LC
  1. R600 Refrigerant.
    By tonydeith in forum Refrigerants
    Last Post: 21-04-2011, 08:52 AM
  2. CARE refigerants by BOC
    By dogma in forum Refrigerants
    Last Post: 23-03-2010, 12:39 PM
  3. Replies: 2
    Last Post: 16-11-2005, 05:34 PM
  4. Liquid refrigerant and bubles in sightglass
    By aygul in forum Trouble Shooting
    Last Post: 30-08-2003, 09:07 PM
  5. Refrigerant Reclamation
    By herefishy in forum Commercial
    Last Post: 23-07-2003, 08:19 AM
