Thread: Fujitsu with Siam Comp NH52VNHT
13-01-2024, 09:21 AM #1
Hi Peeps
I searched throughout the board, though could not locate the info.
Have a failed comp on a Fuj ducted AOT30RMBL an older R22 system using the above Siam NH52VNHT. Fuj spares have the comps no problem, though no longer have the soft starter available, when I checked the same Siam comp is used in Mitsubishi Electric PUH-3VKA though the Mitsu system doesn't use a soft starter only a contactor & run cap.
Can anyone advise any problem in rewiring the Fuj using the same as the Mitsu system?
Thank you for reading.
29-02-2024, 07:09 AM #2
