    Sep 2005
    42
    191
    power overnight stnadby while in motion? (van)
    bit of an odd one
    freezer van... (Mercedes sprinter)
    can the overnight (240v) standby be powered up while the van is in motion to provide cooling (without engine compressor - no space for one, already has aircon and extra alternator) ?
    or will the bumps/vibration kill the 240v compressor?
    electric 12v systems are priced really high
    could buy a 12v compressor, but might as well use the mains one when it's there
    Oct 2003
    5,630
    Re: power overnight stnadby while in motion? (van)
    Sure, with very long cables...
    Feb 2011
    scotland
    462
    Some trailer units have a three phase vertical scroll compressor they run on road and standby (Carrier Vector), not sure if there a special model or just an ordinary comp though.
    Jun 2023
    Are 12VDC to 240VAC invertors not an option here? a couple of decent batteries and a couple of extra alternators should keep a big ole invertor going
    may not be the most efficient solution
    if you have any doubts about the ability of the compressors ability to cope with travel while running the additional vibration compensation shouldn.t be difficult to achieve
    Sep 2005
    42
    191
    an extra battery and an inverter are exactly what I'm thinking
    a lot of shop delivery vans around here use electric systems... but they have a 12v motor belt driving a standard engine mount compressor... seams a bit noisy to me
    not sure if it's the same in the rest of the world?
    EDIT: just googled it to check... the supermarkets use a "Carrier Neos 100" system...
    1.2kw of cooling at 0'C and 470watts of cooling at -20'C (no idea on ambient temp for those)
    electric motor is 1420watts.... so 118amps at 12v :-o
