04-09-2023, 07:15 AM #1
have some questions ( sorry im new and bad in english)
1) When Room 1 door opened,the temperature of the freezer room which is (-20c) will dropped by how many? The temperature of the Ante room (+5c).
2) since the outside temperature is (+35c), the temperature of the Ante Room (+5c) will be affected by how much?
*the number of times people Open the door per day is over 800 to 900 times. (for both Ante Room and freezer Room to keep stocks)*
Panel thickness size is 1500mm
sorry about the question that i asked....my english is not that good, its my 1st time posting things that i needed help with. and sorry.. if my questions are weird, please correct me.
07-09-2023, 11:11 PM #2
Re: have some questions ( sorry im new and bad in english)
02-10-2023, 03:26 AM #3
Hi Josip, thank you for your answer.
regarding about what good i'm keeping within freezer rooms.... the rooms are used to keep frozen meat/fish. they were all kept in a big packages, only some are kept in a plastic boxes. And yes.... we move the goods in and out by using forklift.
the workers will take the goods out from the freezer room and starts to repack the goods at Ante Room, after repacking the goods (big package into small packages), they will ship out the goods. Some of the goods will be put back into the freezer room, that's why the number of times the doors being opened are a lot. they will keep going in and out of the room. (you are right...its like opening the doors all day)
17-10-2023, 02:08 PM #4
The presence of an oil separator on the condenser indicates that it is designed to handle the oil return from the compressor effectively. This is particularly important in systems where the compressor is located some distance away from the condenser. The oil separator helps prevent excessive oil accumulation in the condenser and ensures proper lubrication of the compressor. Ensure that the oil separator is clean and functioning correctly during maintenance and troubleshooting.
