Results 1 to 27 of 27
Thread: INVESYS ECH 210B PASS help
11-03-2023, 06:34 PM #1
Please repairmen, if they have a password to enter the parameters of the purchased second-hand Invensys ECH 210B controller?
This would replace my defective pictured below. Thanks in advance. Cheers
Cela remplacerait mon défectueux dans l'image ci-dessous. Merci d'avance. Salutations
upload pics in a link
This would replace my faulty one in the image below. Thanks in advance. Cheers
Please if you have a technical manual for this heat pump.
11-03-2023, 07:06 PM #2
Re: INVESYS ECH 210B PASS help
Sorry for my bad English, if you can help me I will be very grateful. Greetings
11-03-2023, 08:54 PM #3
Try 22 or 12, it looks a bit like an elliwell.
11-03-2023, 09:57 PM #4
Thank you, but unfortunately it is not, it is an Invensys ECH210B controller.Thanks, but unfortunately it's not, it's an Invensys ECH210B regulator. Do you maybe know where to get it,"ModbusRequestPro" Regards Greetings
12-03-2023, 08:01 AM #5
It could be 177
12-03-2023, 08:19 PM #6
Or 135 for all Eliwell
13-03-2023, 07:56 AM #7
Thank you, but unfortunately it is not.This is the answer from the Elliwell help desk!Regards Greetings
Dear sir,
I am sorry but we do not know the password.
Passcode has been set by the appliance manufacturer and there is not way to bypass it
ThanksLast edited by dfranc; 13-03-2023 at 08:23 AM.
13-03-2023, 08:01 AM #8
13-03-2023, 11:05 AM #9
There is a contact link on their web page for this model
https://brightcac.diytrade.com/sdp/4..._recovery.html
Or you could just replace the controller with a new Eliwell or similarLast edited by frank; 13-03-2023 at 11:06 AM. Reason: Typo
13-03-2023, 11:15 AM #10
13-03-2023, 03:30 PM #11
Did you try pass 77?
13-03-2023, 05:30 PM #12
13-03-2023, 06:32 PM #13
https://brightcac.diytrade.com/sdp/435477/4/home/0.html
I managed to open this, but my pump is missing?
13-03-2023, 06:54 PM #14
But the contact link is there, so you could email them for help
13-03-2023, 07:39 PM #15
13-03-2023, 09:00 PM #16
Invensys is now Schneider Electric
https://www.se.com/ww/en/brands/invensys/invensys.jsp
13-03-2023, 09:03 PM #17
14-03-2023, 08:15 AM #18
HI
another Modbus Request Software : Modscan32 or 64
available here in demo mode (or with license):https://www.win-tech.com/
a quick demo :https://www.youtube.com/watch?v=STBX1Nc2I0s
15-03-2023, 08:17 AM #19
15-03-2023, 05:45 PM #20
Yes,but you still need password
15-03-2023, 09:35 PM #21
I tried from 0-255, and it won't open the parameters, there isn't even a -set- mark, and on the old one, when I press both buttons, it first shows -set-, and then it goes on to PAR-CONF, H1, etc.
16-03-2023, 04:36 PM #22
what problem do you have? why do you need to enter to the parameter? change what?
17-03-2023, 05:47 AM #23
This is the second controller, which needs to replace my old one, but it was on another pump, so the parameters need to be changed, which is an impossible mission. It seems that the factory or the former owner turned off the pass and code to enter the config mode. Now I can't learn even with modscan, not even with Dial_ECH2XX_ModBus_1.1.3, and modbusreqestpro, I can't find it. Regards
31-03-2023, 03:52 PM #24
03-04-2023, 05:08 PM #25
I got the instructions here, but I haven't tried it yet. Greetings
https://chaleurterre.com/forum/viewt...162271#p162271
private image upload
08-05-2023, 11:04 AM #26
A password will be requested to perform this operation
On the display, it is shown - - -• Type the password value corresponding to the parameter value Pa H47 ,,,,neeting - - -• Il n'y a pas de possibilité d'entrer un mot de passe,,,,,
Nothing! There is no possibility to enter a password
Either the copy card is faulty or it needs to be formatted, but how?Last edited by dfranc; 08-05-2023 at 11:10 AM.
18-06-2023, 10:51 PM #27
