    Feb 2011
    scotland
    461
    Hydraulic fittings
    What hydraulic fittings/adaptors have you found useful to have for working on industrial plant? For being able to connect a hose or a gauge, that sort of thing.
    Come across 1/2" BSP 60º cone, 1/2" BSPP flat face, 6L compression, 6mm Swagelok, 1/4" 45º SAE flare.
    Jun 2017
    Norway
    32
    Re: Hydraulic fittings
    Here in Norway we mainly use 1/2" BSPP flat face and 10L compression fittings, these are normal on Danfoss SNV valves. Most common on mycom compressors to have have 3/8 npt fitting for screwing in hose when de-pressurising units.
    Feb 2011
    scotland
    461
    Cheers HwT
