    Oct 2003
    5,630
    Different log ph for same refrigerant
    How it comes the difference in the enthalpy for same refrigerant?
    Jan 2020
    EU
    Re: Different log ph for same refrigerant
    Different gas manufacturer?
    Aug 2021
    Scotland
    14
    bit hard to make out, can you point out the differences?
    Oct 2003
    5,630
    Quote Originally Posted by skarrs71 View Post
    Enthalpy differs at a given pressure and temperature.. Just have a Quick look to the enthalpy scale of both
    Unfortunately the two scales are just different levels of blur.
    May 2012
    1,528
    I think the HVAC one is wrong. the values are not the same as other comparators.
    Rob
    Oct 2003
    5,630
    Sorry, hitted the wrong button first...
    I saw the same errors with R134a and R22 as well and found also errors in the calculation of Coolpack... Solkane and Coolselector gave same results where Coolpack gave complet different numbers when plotting and calculating a log p/h
    Feb 2011
    scotland
    463
    Could errors from unit conversions be a possibility?
    May 2012
    1,528
    I suppose we trust the information we are using at the time.
    So if I was using Coolpack I would trust their numbers but I have sutle differences before with
    different comparators but those two you have seem to be Bars out.
    The most I have seen is a confusion between Gauge and Absolute.
    Rob
