    Feb 2020
    Pakistan
    27
    Double Separator In Series or Parallel
    Hello Experts,
    Can we apply 2 separator vessels in series or parallel to increase Separation time? What type of controls would be required in this case?
    Please share your experiences
    Sep 2009
    Iran
    66
    674
    1
    Re: Double Separator In Series or Parallel
    If your oil separator is small you can add another oil separator to increase it .
    This best way put new one in series.
    Return oil should come to crankcase of compressor
    And to be safe side with another pipe .
    Feb 2020
    Pakistan
    27
    Dear Michael,
    I am talking about refrigerant gas and liquid separator I.e low pressure compressor suction vessel.
    Sep 2009
    Iran
    66
    674
    1
    Sorry I had mistakes.
    To build and make this system might cost more money than make big one .
    To do that system should be parallel and should be connected from butom and top side with large size pipes . (To have equal level liquid in both separators)
    Bottom line should have oil drain.
    It is better your inlet liquid and suction line from Condenser and Evaporators come to one side and your out line suction to compressores goes from other one.
    Again to build and operate one big liquid separator is better than to have 2 liquid separator in parallel.
    Feb 2020
    Pakistan
    27
    Are you proposing parallel separator vessel?
    What are disadvantages of series system?
    Jul 2006
    865
    Separators work by slowing down the velocity of the suction gas as it flows through a vessel. The gas slows down and the liquid falls out. There are some ways to increase the effectiveness of a separator as mbc mentioned.
    Putting them in series might work somewhat but I do not believe that it would be nearly as effective as a properly designed larger vessel.
    Sep 2009
    Iran
    66
    674
    1
    Hi NH3LVR
    As you told .
    we can not use series in suction separator
    We have to pump liquid to our system
    All retrun liquid from suction line and also from receiver would be in frist one and also we should have enough surface area for boiling of NH3 Liquid so second one does not doing any work to us .
    One big one is better 2 small one and it should be in parallel.
    But in oil separator series is better than parallel
